Watershed Area for Random Point
1677
08-15-2013 11:12 AM
LenDesson
I took a DEM and made a Flow Direction waster from it, ran Sink, there were some, and ran Fill.  Re-ran Flow Direction.
What I am trying to do is find the Watershed for a random point (not necessarily a pour point).  If I locate my random point and then run the Watershed tool, the tool gives me a very small area which does not seem to represent all the upstream cells that drain to it.
I found this really helpful link and though the processing extents were my problem, but I made sure to set those properly and I am stillgetting the small area result.
http://forums.arcgis.com/threads/78317-Watershed-tool-returns-only-immediate-catchment-not-entire-up...
Any ideas or other ways to go about it?
NeilAyres
You need to use the snappour command / tool to snap your "random" pour point to a cell of highest accumulation within a certain radius.
If you just input any "random" point its likely that you will get many that have a quite tiny "watershed".
You will not see the small imperfections in your dem that are causing this.
N
NeilAyres
N
LenDesson
N
Yep, this was the step I was missing... the Snap Pour Points tool snapped my random point to the closest high accumulation flow line, returned a raster which I was able to feed in to the Watershed tool to delineate the real watershed.
