Viewshed vertical angle problem
3100
08-05-2019 11:27 PM
RobertoFilloramo
I use ArcGiS 10.1 and I am doing some visibility analysis by using the viewshed tool. I need to set the vertical angle (VERT1-2) within a range between 0 and 180, but this parameter is enclosed between 90 and -90 so it didn’t permit me to calculate the visibility. Is there some way to perform this calculation?
ModyBuchbinder
Hi
The values are from the horizontal line that is zero.
+90 is basically unlimited (looking up to the sky) and -90 is looking directly down.
What do you mean when you say "within a range between 0 and 180"?
RobertoFilloramo
Mody Buchbinder‌ thank you for replying me, I meant that I need to set Vert1 as 0 and Vert2 as 180. I tried setting these parameters but the tool gave me error, so I presumed that it was because of the 180degrees angle value.
ModyBuchbinder
Hi Roberto
Why do you have to put 0 and 180 when -90 and +90 represent everything you can see
The tool is build to get -90 and 90 and cannot handle other values.
Please explain what vert2 = 180 represent.
RobertoFilloramo
Mody Buchbinder‌ Well, because I want to fix the visibility on the land/skyscape within these range. Therefore, being 90 degrees a fixed value I can’t type a bigger value, right?
