Viewshed and cumulative viewshed question
1697
06-27-2021 02:01 PM
ChrisM
I posted this over in Geoprocessing the other day and thought I'd seek input here
I've been doing a lot of comparative research on creating viewsheds and comparing the data, not just in ArcGIS but other platforms and general theory. I keep running into some issues. Let me explain.
I have 10 sites on hilltops that I want to assess intervisibility. The line of site analysis is not great in this case. So, I just calculated viewsheds for each site, converted the visible raster data to polygons and determined which sites fall into each other's viewsheds. Fairly simple, though not without some issues and simplifying assumptions. I can also, of course dependent on the size of the base DEM and other parameters, determine what the average viewshed area is for each site.
However, I want to do a couple of additional things. I'd like to be able to compare the overall average viewshed or visibility of the sites with what the average visibility would be throughout the area, regardless of physical location. That is, I'd like to assess quantitatively if the hilltop locations have over all better visibility than other locations. First, I used the raster calculator and added all the site viewsheds together to create their total viewshed. This obviously wasn't necessary since both the viewshed tool and the visibility tool produce the same resulting raster data product. Nevertheless, that's what I did.
To get the comparative dataset, I generated 1000 random points in the study area, focusing a tad more in the middle to reduce edge effects. In this case, I can't take the time to generate individual viewsheds for each point, so I just did the visibility analysis. As I said, I could have done that with the hilltop sites, but then I would not have been able to really assess what each hilltop sites individual viewshed areas were. Anyway, doing this produces another raster. You can clearly see that the hilltop locations are very visible in the random set, but that they have an over all lower visibility.
However, making meaningful comparisons is hard. I looked at the source statistics for both rasters, and you can see that the mean for the hilltop total viewshed raster is much higher (assuming that the source statistics are recording visible pixels, which I guess they would have). But how do I compare these statistically? That's my over all question, but here are some embedded questions that keep popping up:
1) To compare these two rasters, would I need to normalize them to put them in the same scale? In this case, would I need to divide the rasters in the raster calculator by the number of sites used (10 and 1000) (or would I normalize by the number of pixels (I doubt this since they are the same in both cases).
2) Although the viewsheds show how many many pixels (Count) are visible by how many sites (value) it does not show which sites are visible and it does not show what the area of viewshed is for each site. Now, I can do this with more steps with the 10 hilltop sites, as I discussed above. Conversely I can use the Observer Points tool (or the observer function in visibility) to produce a table that lists the observer points that are visible and the number of pixels visible. I could sum up all the times each site is listed as 1 and add up the counts for them to get the differences in their viewsheds in terms of pixels. This really isn't necessary since, as I said, I can do that more easily by either recording the total visible pixels in their individual viewsheds or convert the visible portions of the individual viewsheds to polygons and calculate area. However, and here's an issue, I can't do that with the random points. Observer point tool has a 16 point limit and, as I said, calculating individual viewsheds for each 1000 points would take too long. I played around with extracting the underlying raster data and appending it to the point data files for each group, but I realized that that does not give me what I want at all, and I'm not really sure what that data is saying anyway. In otherwords, the rasters show visibility in terms of the location and number of pixels viewable by a particular point and give an average visibility. They don't show what the sizes or average sizes of the individual viewsheds are for the points. So, the rasters help address one question (average regional visibility of all hilltop sites against average regional visibility in general as approximated by a series of 1000 points) but they don't address another question (the average size of the viewshed against the average size of the viewshed of the random sample).
3) If I am stuck just comparing the hilltop total viewshed against the random point viewshed, what kind of tool can I use to test for significant differences? I can't see much in arcmap. I thought about just generating new point files for each raster, with a point for every pixel and with the raster data as the point attributes. Then, at least, I could have a data file that I could more easily calculate means, etc. and conduct some tests. But, as I said, the source statistics for the rasters are there. But how can I compare them meaningfully?
Anyway, I'm sorry that this is so long. I suspect a number of other issues and problems might arise or be obvious in my post.
