Value range changes when using mosaic
2728
09-02-2013 01:40 PM
JeffBoyd
When I use the mosaic tool to combine two or more integer (or float) rasters, originally DEM's, the value ranges (elevation) change.  For example, one raster has a range of values from 1189 - 1513, the other 1215-1557.  I expect the mosaicked raster to range from 1189-1557.  But, instead, I get a value range of -32768 to 32767.  So, the mosaicked raster is useless to me.
JimCousins
Jeff,
It sounds like you need to calculate statistics on your resulting raster dataset, to get ArcMap to find the min and max values.
Regards,
Jim
JeffBoyd
Jim,  I tried running statistics on both rasters, and got the same result when running mosaic, so my problem hasn't changed.
thanks
Jeff
JimCousins
Have you run statistics on the mosaic output?
