Using log scale for color ramp
2910
07-09-2019 09:55 PM
ChrisLi1
Hello.
When using a color ramp to display a raster, how do I change the color ramp to log scale?
I did some research and came across the post below, but still can't find a solid answer.
https://community.esri.com/thread/45404
Many thanks,
Chris
Tags (1)
HermioneMessi
I have the same question, have you found the solution?
DongchenWang
Same question. There should be a simple and easy solution. If not I recommend ESRI add this function in the colormap.
JV_
No answer yet? I have the same problem, how did you fix it?
MatthewHallissey
Seems like there is no option for it....
Was also trying to use it myself and looks like you can just take the log of the data but the color ramp will still be linear.
