Topo To Raster "Error in executing grid expression"
3373
11-30-2011 05:56 AM
TimLemmens
Just to let you know in case you're desperately looking for a solution for this same problem...
When running the "Topo To Raster" tool from Spatial Analyst, I continuously got the error "ERROR 010067: Error in executing grid expression." This was driving me crazy, as even the most simple dataset (no zero-length polygons) on a local drive in non-space directories didn't produce any results.
In the end I could solve the error by changing my regional settings to "English (United States)" so that the decimal delimiter would be a dot "." instead of a comma ",". Now I can successfully use the tool... Strange but problem solved for now 😉
best regards
tim
SteveLynch
Tim
What version and which service packs were loaded?
Steve
TimLemmens
Hi Steve,
Currently AG 10 SP 2, but I will shortly upgrade to SP3.
If you think it would make any change, I can test it again for you...
regards
tim
SteveLynch
Tim
Please apply SP3 and reply to this thread with your findings.
Steve
