Problem using 'Collect Values' with 'Cell Statistics' in Model Builder
1222
10-30-2011 11:18 AM
SakuraOno
I'm having a lot of trouble getting 'Cell Statistics' to work in Model Builder. In my model, I have some iterations that lead to me having a set of rasters, which are collected by 'Collect Values' (this is done in a sub-model). However, when I use the output of 'Collect Values' (in the main model) as the Input for 'Cell Statistics', I keep getting error. Even though in the ArcGIS Desktop Help page it explicitly said this should work (http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//004000000005000000.htm)
I know for a fact that everything else is working in my model because I manually carry them out, and the error message I get is specifically directed towards the input of Cell Statistics. I also know for sure that my iterations are producing the rasters correctly, because when I input them manually (by selecting each raster individually) to 'Cell Statistics' it works fine. It is when I want it to do it automatically (the reason why I'm doing a model) that becomes a problem!
So essentially, the set of rasters I have in the output value of 'Collect Values' cannot feed into the Input of 'Cell Statistics'. In fact, it cannot feed into any other tools that deal with a set of rasters (such as Combine Rasters, or Mosaic to Raster, etc.). So unless I manually specify which rasters to feed into Cell Statistics, it just won't work....
Can anyone help? Or does anyone know if this is actually a bug in the software? because I'm going crazy :(:mad: :confused: and can't seem to figure this out.... please help! thank you very much!!!
XuguangWang
How many rasters are resulted in the "collect values" tool? Which release version (and service pack) of ArcGIS is used here?
DanBoitshoko
What error message does it return? Does it tell you that the files you are trying to feed into the "Cell Statistics" tool do not exist?
Try this.
Make sure that the variable that feeds into the collect values tool is NOT set as INTERMEDIATE
