Syntax for Merge with map algebra in ArcGIS 10
3800
06-08-2011 11:52 PM
GraziaZulian
Hi
With arcgis 9.x there was the Merge operator for the map Algebra syntax
Es:
MERGE (ras1, ras2)
What is the equivalent command for the new version?
How do I use it in a python script? Thanks, Grazia
TimothyHales
Esri Notable Contributor
You will need to use the Mosaic to New Raster tool.
This is a Python sample for the MosaicToNewRaster tool to use in the Python Window.
import arcpy
from arcpy import
envenv.workspace = "c:/data"arcpy.MosaicToNewRaster_management("land1.tif;land2.tif", "landnew.tif",\
        "World_Mercator.prj", "8_BIT_UNSIGNED",\
        "40", "1", "LAST","FIRST")
There is also a python standalone version at the bottom of the tool's help page:Mosaic To New Raster
Also see the following thread: Raster Calculator Merge Function in ArcGIS 10?
GraziaZulian
thank a lot
Grazia
