SUMMATION USING ARC MAP(RASTER CALCULATOR)
13517
39
03-17-2015 12:10 PM
deepa_davis
WHILE CALCULATION  AN EXPRESSION HOW TO PERFORM SUMMATION WHICH IS NOT FOUND IN RASTER CALCULATOR.
deepa_davis
SIR D drive is not available, what to do in the edit option?can tel the steps to be done?
JayantaPoddar
Hi Deepa,
The issue is that the output location in the tools refer to D-drive, which is eventually not there in your system, thus the error popping up.
Go to ArcCatalog > (Locate the path of the model) > Right-click the model > Edit
In the model-builder window, double-click the tools (in orange) and define valid output file path. The default model had D-drive in path. Verify for all the tools. Also make sure you replace the DEM with the DEM file available with you. Also verify K_factor, C_factor, P_factor, and R_factor.
Let me know if the issue persists.
Jay
Think Location
deepa_davis
deepa_davis
CHANGED EVERY OUTPUT FILE LOCATION ,STILL SHOWING SAME 2 TYPE ERROR SIR
deepa_davis
SIR FINAL I GOT 3 RASTER MAP FOR(P*R,C*K,TIMES).ACTUAL WHAT IT MEANS?DO I HAVE TO MULTIPLE THESE 3 TO GET FINAL VALUE?
deepa_davis
deepa_davis
SOIL EROSION VALUE IS THE RASTER WHICH MEANS TIME?
deepa_davis
SOIL EROSION VALUE IS THE RASTER WHICH MEANS TIMES?
deepa_davis
IS THIS VALUE IS SEDIMENT YIELD IN TONES/HECT/YEAR? OR ANY CHANGE IN UNITS?
deepa_davis
