SUMMATION USING ARC MAP(RASTER CALCULATOR)
13614
39
03-17-2015 12:10 PM
deepa_davis
WHILE CALCULATION  AN EXPRESSION HOW TO PERFORM SUMMATION WHICH IS NOT FOUND IN RASTER CALCULATOR.
DanPatterson_Retired
You wouldn't by any chance be trying to save this to a USB drive/key would you?
deepa_davis
NO SCOPE
deepa_davis
SOIL EROSION VALUE IS THE RASTER WHICH MEANS TIMES?
deepa_davis
S THIS VALUE IS SEDIMENT YIELD IN TONES/HECT/YEAR? OR ANY CHANGE IN UNITS?
XanderBakker
Esri Esteemed Contributor
The invalid output workspace might be due to the single quote in the name. Avoid any special characters in the path, don't use spaces and don't use long names. This may cause errors. Rename the folder "ALL DATA" to "ALL_DATA".
deepa_davis
I HAD GIVEN ALL THE PARAMETER IN RATER(AS PER SPECIFIED),AND WORK SPACE IS ALSO GIVEN PROPER(CHANGED THE ALL_DATA).STILL SAME ERROR? WHAT TO DO SIR?
deepa_davis
NO RESULTS SIR
XanderBakker
You can just download the toolbox: http://www.envsys.co.kr/~sateec/toolbox/EnvSys_SoilErosion_Toolbox_ArcGIS_ModelBuilder.zip  as stated on the website (Soil Erosion / Sediment Yield ArcGIS Toolbox Kangwon National Univ. ) and if you have Spatial Analyst, you will be able to use the toolbox. No need to have a trail version.
deepa_davis
JayantaPoddar
Hi Deepa,
Do you have a D-drive in your system? Please change the output file path for each tool with valid path-names for your system, in the model-builder.
Think Location
