Sum multiple Rasters
9127
02-03-2014 06:49 AM
JustinBrandt
Hey folks,
silly question here, but I can't seem to find an easy answer.  I'm using Arc 10.0...
I have several rasters that are a series of floating point values (several hundred thousand points) where each point is an elevation change over a period of time (i.e. raster1=timeA-timeB, raster2=timeB-timeC, etc...).  Each raster has the same extent, and same number of points (in the same locations).
I want to sum these rasters together (i.e. rastersum=timeA-timeD).  I can use the "Plus" feature in Spatial Analyst, but that only allows you to add two rasters at a time.  Even doing a batch process with Plus is a multi-step process...
Is there a simpler way (i.e. non-python) that allows me to do this?  I'm assuming there is, but I haven't stumbled upon it yet.
Thanks!
Luke_Pinner
MVP Regular Contributor
Raster Calculator: "timeA"+"timeB"+"timeC"+"timeD"
Luke_Pinner
JustinBrandt
Thanks!
I knew it was something simple I was missing.
Had to search around for a bit, though, and finally found the function in Spatial Analyst --> Map Algebra
Seems like of a weird place for it to hide...
SteveLynch
I would use CellStatistics
Luke_Pinner
+1
I always forget this tool...
