Spline with Barriers failed AG10
5335
12
05-25-2011 11:20 PM
martinmaretta
hi use AG10, win7, and i have problem whit interpolating using Spline whit barriers. I have jre6 installed so there is no problem whit Java. When I start the tool, start computing (reading, interpolationing..) but then suddenly fail.  Do anybody know, how to solve this problem? thanks a lot. M.
SteveLynch
Anke
In ArcMap (Python window) or via a Python script, do the following
import arcpy
arcpy.GetSystemEnvironment('AGSDESKTOPJAVA')
Navigate to the folder printed above and navigate further into java\jre\bin
do you have java.exe in that folder?
Also look and see if you have a system environment variable called AGSDESKTOPJAVA and it'll point to what is printed by arcpy.GetSystemEnvironment('AGSDESKTOPJAVA')
Regards
Steve
JeffRiley
Has anyone found a solution to this issue? I am using Arc10.1 and have experienced the same problem as mentioned above. The error message is a generic 'failed to execute' just as the original poster and says nothing about JAVA. I check that anyway using the above suggestion and my java.exe is present and up to data. I have tried all of the suggestions listed above to no avail. I can use all of the other interpolation routines it is only when I try to use a barrier with the spline that it fails. Any help is appreciated.
-Jeff
SteveLynch
Jeff
Please email me your input point feature class. Also what field are you interpolating on and are you accepting the default cell size?
Steve
[email protected]
