Spline with Barriers failed AG10
5329
12
05-25-2011 11:20 PM
martinmaretta
hi use AG10, win7, and i have problem whit interpolating using Spline whit barriers. I have jre6 installed so there is no problem whit Java. When I start the tool, start computing (reading, interpolationing..) but then suddenly fail.  Do anybody know, how to solve this problem? thanks a lot. M.
martinmaretta
see attachment..
SteveLynch
Please try to narrow down the problem, viz.,
- use a smaller dataset, with and without a barrier
- output to ESRI grid rather than fGDB
- create a new fGDB and output to it
- with you posted scenario, increase the cellsize and exclude the barrier and output to ESRI grid
Please let us know which of these are successful.
Steve
martinmaretta
hi thanks for reply.. i tried all those things before..but is still the same..  the same error
SteveLynch
Can you run Spatial Analyst's IDW with the data, output cell size and output location and raster format?
Steve
martinmaretta
hi there is no problem whit IDW   whit and also whitout barriers
SteveLynch
Please can you contact Esri Support.
Thank you
Steve
JenniferBarrett
Did you ever solve this? I keep getting the exact same error and have tried everything I can think of with no luck!
Thanks!
Cheers,
Jenn
SteveLynch
Jenn
Can you share the data ([email protected])
And you do have java installed and you did try IDW?
Steve
AnkeRiethmueller
Hi there,
is there by now an official ESRI solution to this problem? German support already tried it´s best, but we with no result.
Facing exact the same error.
I changed AGSDESKTOPJAVA back and forth to various locations and also changed betweem JRE6 and JRE7, nothing worked.
Is there a secret how AGSDESKTOPJAVA and PATH have to be configured? To which exact folder does the AGSDESKTOPJAVA need to point and do I necessarily need to give the location to java.exe in the PATH variable?
Regards,
Anke
