Spatial Analyst  -Line density tool not working in Arc10
1656
04-07-2011 12:47 PM
SriniVasan1
I have road features in a shapefile that I want to get linear density on but despite several attempts, it is not going through.  It comes up with a red X with no specific error message.  I have tried several times on several machines with different cell size and radii.  Has anyone else encountred such a problem?
S
TimothyHales
Esri Notable Contributor
When you click on the red x it should give you an error message.
Try changing the output location to your C:\temp folder and also make the name is no longer than 13 character unless you specify an output format other than grid.
SriniVasan1
Thanks for the suggestion.
Later on, I discovered that a GDB that was a Personal GDB was set up by a third party.  When I switched over to File Geodatabase the problem did not happen!
