Create a raster of latitude
3356
10-20-2011 05:35 AM
DanRosauer
Hi
Can anyone suggest a simple way to create a grid where the cell value is simply its latitude?
Ultimately I want to apply a function of latitude to generate a value for each cell.
Any solutions in the arc toolbox or python would be cool.
thanks
Dan
Luke_Pinner
MVP Regular Contributor
Dan, what version of ArcGIS are you using?
If <=9.3.1 you can simply use the grid variable $$YMAP in any Map Alegbra expression (ArcToolbox or Raster Calculator) - assuming you are working in a geographic coordinate system and you have set your analysis environment up (cell size, extent, etc).
In 10.0 this has been removed (or hidden). You can still use it with a little bit of python scripting, see http://forums.arcgis.com/threads/18608-internal-grids-rowmap-colmap-xmap-ymap#post106446
