Spatial Analysis Question
675
10-16-2025 02:54 AM
EugenioBogliani
Good morning everyone,
I'm working for the first time on SAR data and i find myself stucked. I have polygons of landslides and i have the points from the SAR data with the velocity for every point. I need to calculate the mean velocity of the control points inside every polygon, so i tried using Summarize Within but it still gives my this 100014: Summarize within failed.
I checked the names of the fields and they should not overpass the limit of the geodatabase files.
Thanks in advance
DanPatterson
MVP Esteemed Contributor
There are several Summarize Within tools
This one?
Summarize Within (Analysis)—ArcGIS Pro | Documentation
A screengrab of the inputs to the tool, the source and destination paths would help
The full error message and its causes can be found here
Error: 100014: Summarize within Failed
so this should narrow down the cause
... sort of retired...
