Snap Pour Point Not Processing
12705
10
12-06-2018 12:58 PM
DougHaller1
I am trying to create a watershed around a small lake. I clipped the DEM down from the size of a county to about 6000 meters x 3500 meters. I followed the following steps per esri (How To: Create a watershed model using the Hydrology toolset )
Step 1: fill - input DEM clipped to 6000x3500m
Step 2: flow direction - input fill created from step 1
Step 3: flow accumulation input flow direction from step 2
All the above steps work fine...
Per esri: ther input a point feature class or a raster as the 'Input raster or feature pour point data'.
Step 4: I input the original dem (clipped to 6000x3500 m) and input the flow accumulation (step 3 result) per steps - see link above
I set the snap distance to 1000 (m) hoping that the larger the snap the shorter the running time as I tried smaller values previous and the processing took hours/ not minutes or seconds.
Image shows screenshot of results and TOC.
Any suggestions? Thanks in advance.
OliviaFisherWilliams
Hi all-- any thought why my snap pour point is not working at any distance other than 0.
