slope analysis
2696
11-15-2010 11:50 AM
PaulHood
When I use the Spatial Analyst extension to complete a slope analysis on a DEM the classification doesn't make any sense.  The following is the classification when using the percent option:
0-119706.2706
119706.2727-217647.767
and these number continue past 2,000,000.
When I use the Degree option the image appears a solid color and it won't let me classify more then 1 class which is 0-90...
In addition, I have been able to successfully use the aspect tool.  However I can't figure out how to analyze a group of GPS point on top of the raster.  I am trying to figure out which aspect the points are usually on.
DanPatterson_Retired
ensure that your data are projected (not projected on the fly) and that the X, Y and Z values are in the same units (ie meters, feet or the z-factor is accounted for using an appropriate scaling factor).  These issues are discussed in the help files should you require further information.
