Rerunning batched raster tools - output raster greyed out
1736
7
08-30-2017 06:06 AM
gunnarberglund
I'm trying to rerun a batched raster analysis (point statistics). However, when I open the batch grid, the output raster field is greyed out/inactive except for the first line. Anyone know if this is a bug or have a workaround?
DanPatterson_Retired
sounds like the results already exist and a new input is required before you can continue
gunnarberglund
To me, one of the great things about the results tab is the ability to run tools over and over, trial and error. Change some settings, change the input data etc. This works fine with vector data, both single and batched processes. In batched raster operations however, this does not seem to work.
gunnarberglund
I have checked the overwright output features box, and I have tried deleting all outputs before trying rerun. No luck.
so obviously, nothing will be overwritten if it is in arcmap or pro... that leaves a few functions that I know about that will not be overwritten regardless of the settings.  In cases like that, save, close and restart arc-whatever is often what is needed...
gunnarberglund
This is in ArcMap. All (well, most) outputs will should be overwritten with said settings. And I have tried the close/restart solution.
curtvprice
MVP Esteemed Contributor
I believe that Model Builder iterators are often better solution than batch for many one-off workflows like this. I'd look into it.
