request for assistance
1548
03-08-2024 02:16 PM
abebebezu
I am estimating soil loss using the RUSLE model. However, when I calculated the LS factor, most of the pixels resulted in no value. Please tell me how to correct the problem. I used the formula: LS = Power("wateshed_acc" * 30 / 22.1,0.4) * Power(Sin("slope_deg") * 0.01745 / 0.0896,1.3)
DerekLaw
Esri Esteemed Contributor
Hi @abebebezu,
You will have more success getting help from these forums if you post some additional information:
  • Which ArcGIS product are you using? Which version?
  • Which spatial analysis tool are you using?
  • What kind of data are your performing the analysis on?
Then perhaps post your question in the appropriate product forum.
Hope this helps,
abebebezu
Thank you for the immediate response
  • I am using ArcMap version10.4.1
  • The spatial analysis tool used was raster calculator from map algebra
  • The calculation was on raster data
DerekLaw
Hi @abebebezu,
I've moved this thread to the appropriate discussion forum, as I am unable to answer your question.
FYI, ArcMap 10.4.1 was retired on Feb 1, 2022.
You may want to consider migrating to ArcGIS Pro.
Hope this helps,
