Redefining Bins from After Spatial Interpolation
2857
11-01-2015 10:02 AM
SamanthaWright1
Hi all--
After creating about 90 maps using Kriging in the Spatial Analyst tool, I found that it created different legends based on the minimum and maximum values. In order to see compare what is spatially happening, and analyzing minimum and maximum values of all the maps, I have calculated a standard binning number and the specific ranges.
I have tried using the symbology tab and redefining the ranges, and found that that doesn't change the value at each point. Because all of the values are all less than 1, I also found I cannot use the Reclassify tool. Is there a tool or method that can be used for changing 9 ranges into 20 ranges and can be in a more precise data type, and preferably have a batching method?
Samantha
DarrenWiens2
This doesn't seem true to me. I just ran Reclassify with rasters all negative, and decimals between zero and one. What is the error, or problem, with running Reclassify?
