Reclassifying a raster produces �??weird�?� values!
8464
6
05-25-2012 12:21 PM
JamalNUMAN
Legendary Contributor
I wanted to reclassify the raster shown in the screenshot below:
[ATTACH=CONFIG]14663[/ATTACH], [ATTACH=CONFIG]14663[/ATTACH], [ATTACH=CONFIG]14664[/ATTACH][ATTACH=CONFIG]14665[/ATTACH]
1. The maximum cell value in the raster doesn�??t match that one shown by the �??reclassify�?� tool! How come?
2. How come the reclassify tool doesn�??t see the maximum value existing in the original raster and thus more values appear rather than the ranges specified on the reclassification!
How to overcome this problem? How to let the �??reclassify�?� tool see all the values of the original raster?
Thank you for the help,
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: SaultDon
That is a strange issue..
Can you increase the sampling size to anything higher than the "Count"?
Your count is 343809 so try to use a sampling size of 345000, for example.
I think by default your sampling is set to ~10,000.
JamalNUMAN
Thank you for the answer.
I�??m not sure why the �??reclassify�?� doesn�??t read the values from the input raster! That�??s really frustrating!
How can I switch the sampling size? Could you please elaborate more?
[ATTACH=CONFIG]14668[/ATTACH], [ATTACH=CONFIG]14669[/ATTACH]
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Look back at your first post, in the first screenshot.
The sampling button is in the window where you modify the 'class ranges'.
I think you press the "Classify" button inside the "Reclassify" tool.
JamalNUMAN
Many thanks for the prompt answer.
Sorry but I couldn�??t know how to change the sampling size. The screenshot is below.
How to change the sample?
[ATTACH=CONFIG]14691[/ATTACH]
Jamal Numan
by Anonymous User
Not applicable
Original User: erictrice
Jamal,
Please follow the steps in the knowledge base article to resolve this issue.
HowTo:  Compute the histogram with all the unique values, when using the classified renderer
Regards,
Eric
JamalNUMAN
Jamal,
Regards,
Eric
Many thanks for the help. I�??ll try it and let you know
[ATTACH=CONFIG]14873[/ATTACH]
Best
Jamal
Jamal Numan
