Reclassify problems
4532
08-03-2015 04:45 AM
by Anonymous User
Not applicable
When I try to reclassify my raster into 5 classes using quantiles or other methods, arcgis return a raster with an extra class (775)...
How to solve this problem? can someone help me? I'm using ArcGis 10.3
by Anonymous User
Not applicable
Solved!
Float Raster --> int Raster --> reclassify
by Anonymous User
Not applicable
Solved!
XanderBakker
Esri Esteemed Contributor
Glad you solved it. However, the Reclassify tool should work on Floating rasters too (without creating additional classes).
XanderBakker
Can you include a screen capture of the definition of the classes (the Reclassify tool)?
by Anonymous User
Not applicable
Solution N°2:
convert 64bit float raster to 32bit float using copy raster
