Raster to Polygon fails with empty input
12361
15
05-07-2010 03:33 PM
JoeChampagne
When I attempt to run the Raster to Polygon tool with a NoData raster (801 rows and 1400 columns), a corrupted shapefile is output and the following error message appears:
ERROR 010067: Error in executing grid expression.
Failed to execute (RasterToPolygon).
This is an issue because I'm trying to batch process a large number of watershed rasters (some of which are empty) using a Python script (832 tiles), and the script is interrupted when it encounters the first empty raster. Is there any known workaround for this issue? Alternately, is there any way to programmatically check for these invalid inputs?
DanielBennett
Same problem as above. What is the fastest (python script) test that tells me if a raster is all NoData?
I'm thinking SearchCursor:
rows = arcpy.SearchCursor("C:/Data/raster", " ??WHERE NODATA??", "", "",  "")
if is_empty(rows):
    empty = True
else:
    empty = False
SteveLynch
In 10SP1 we fixed it so that Raster To Polygon with all NoData will throw
ERROR 010151: No features found
To test if a Raster has all NoData run the IsNull tool. If the output is all 1 then it only has NoData
Steve
BenLeslie1
Hi - I'm just trying to work round this error in my script....
"To test if a Raster has all NoData run the IsNull tool. If the output is all 1 then it only has NoData"
How do you test whether the whole raster is 1?
NeilAyres
Here is an example of getting the % of nulls in a raster.
# calculate % no data cells in a raster.
import sys, os, arcpy
from arcpy import env
from arcpy.sa import *
if arcpy.CheckExtension("Spatial"):
    arcpy.CheckOutExtension("Spatial")
else:
    print "No SA licence"
    exit
HomeDir = "c:/Data/Swala/BurkinaFaso/IPSurvey/"
fgdb = "IPRasterData.gdb"
InData = os.path.join(HomeDir, fgdb)
env.workspace = InData
env.overwriteOutput = True
ListRast = arcpy.ListRasters()
# ListTable = arcpy.ListTables()
for r in ListRast:
    print "Processing", r
    Ras = arcpy.Raster(r)
    NullRas = IsNull(Ras)
    NCol = NullRas.width
    NRow = NullRas.height
    NCell = NCol * NRow
    Mean = NullRas.mean
    NNull = Mean * NCell
    print "{} % Null {}".format(r, NNull / NCell * 100)
SteveLynch
or
look at the GetRasterProperties gp tool
-Steve
XanderBakker
Esri Esteemed Contributor
Although Neil's snippet allows for determining the percentage of NoData in a raster, Steve provides a solution that does exactly what you are looking for and does not require Spatial Analyst. To show a little what you can do with it, here's a litte sample:
import arcpy
ras = r"D:\Xander\LineasTransmision\Modelo\fgdb\RastersModelo.gdb\cmp_totexl02a"
props = ['MINIMUM', 'MAXIMUM', 'MEAN', 'STD', 'ALLNODATA', 'ANYNODATA', 'UNIQUEVALUECOUNT']
for prop in props:
    try:
        print "{0}: {1}".format(prop, arcpy.GetRasterProperties_management(ras, prop))
    except Exception as e:
        print "{0}: {1}".format(prop, e)
Returns:
# MINIMUM: 22
# MAXIMUM: 396
# MEAN: 97,7094252332071
# STD: 51,5918279932734
# ALLNODATA: 0
# ANYNODATA: 1
# UNIQUEVALUECOUNT: 327
So you will just have to test for the property "ALLNODATA" and when the result is '1', skip that raster.
Kind regards, Xander
EvaSevillano
Useful script!
Is it possible however that a raster has the ALLNODATA = 1 but looks visually ok, has a nodata value defined and the statistics are ALSO provided from the Get Raster Properties parameters: MEAN, MAXIMUM, MINIMUM, STANDARD DEVIATION ??
I am trying to understand why this happens to be able to convert to points afterwards...
Any suggestions for a workaround?
Thanks
XanderBakker
Not sure if I understand... You have a raster that returns ALLNODATA = 1 (so all pixels are NoData values) but does have values (hence the valid stats for MEAN, MAXIMUM, MINIMUM, STANDARD DEVIATION)? If that happens it should be a bug. Is it possible to share the raster? Did you contact support?
EvaSevillano
Yes, you understood correctly.
Strange as it comes from masking a source raster  (like spliting it). The source raster also shows allnodata = 1,  but looks ok, stats ok, values ok, nodata defined ok.
The split rasters some show the allnodata 1 and some allnodata =0. All of them looking ok, stats ok, nodata defined ok.
Sure. I can share. How do we exchange the file?
I only wrote here, as I saw the issue of the allnodata thread.
Thank you! Really surprised with this artifact.
Can't figure out what it is.
Enviado desde Yahoo Mail con Android
El jue., jul. 26, 2018 a 18:38, Xander Bakker<[email protected]> escribió:
#yiv9856133252 * #yiv9856133252 a #yiv9856133252 body {font-family:Helvetica, Arial, sans-serif;}#yiv9856133252 #yiv9856133252 h1, #yiv9856133252 h2, #yiv9856133252 h3, #yiv9856133252 h4, #yiv9856133252 h5, #yiv9856133252 h6, #yiv9856133252 p, #yiv9856133252 hr {}#yiv9856133252 .yiv9856133252button td {}
GeoNet
Re: Raster to Polygon fails with empty input
reply from Xander Bakker in Spatial Analyst - View the full discussion
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in Spatial Analyst by email or at GeoNet
Following Re: Raster to Polygon fails with empty input in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
