Raster Reclassify crashes upon completion
7834
02-08-2013 10:34 AM
BrendanMcDavid
I am using a student edition of ArcInfo. When attempting to reclassify a raster, ArcMap freezes upon completion without throwing any error message. I thought the file was perhaps too large for my system (duo core, 2.1 GHz, 4gb RAM running on Vista x64) so I split the raster into 9 TIFF tiles, but I am still having the same problem with the smaller dataset. The tile I am trying to reclassify is 8bit, 13259, 13950 rows, 7 classes. When I examine the data set reclassify produces upon crashing, it contains the correct raster information (classes, etc), but no spatial reference.  Any help would be appreciated!
LorainDrennan
hi there! did you find a solution to the problem? i am currently having the same problem... looking forward to your reply!
MarkBoucher
Honored Contributor
People are going to accuse me of repeating myself...
  • Set the Customize>Arc Map Options>Raster Tab>Maximum number of unique values to render" to a high number (see image).
  • Uncheck "Enable" under Geoprocessing>Geoprocessing Option - Background processing
  • Try running the process on the data on your C: drive if you are currently working over a network.
These steps have helped me get past geoprocessing crashes.
[ATTACH=CONFIG]25071[/ATTACH]
MahmoudMdookh
Hi.
According to my experience
Do the steps below, and it will work..
AchintyaRawat
Hi Mahmoud, I am having the latest version of ArcGIS Pro so kindly tell how I perform the above step as per the latest version?
