In the Overlay Analysis tool, do you need to set a Scale Value to a Field Value to Rasters already Reclassified?
And what about the Evaluation Scale; If I've already Reclassified the Rasters to a Common Scale, why do I need to set this?
Thanks!
Are you in this toolset? and following this workflow?
Yes, sorry, I'm in the Weighted Overlay tool.
It's not clear to me how I relate my already Reclassified Input Rasters (on a scale of 1 to 10) to the Weighted Overlay tool's 'Scale Value' and 'Evaluation Scale'..?
Thanks.
From the link I sent you, step 4 has been completed by you. Your remaining task appears to decide on how to weight your input variables so that they total 100%. Is this what you are needing help with?
The Weighted Overlay tool contains more Input sections than the weights, themselves. My Question is about the 'Scale Value' and 'Evaluation Scale' inputs and how I relate and use them with my reclassified data. ...That's ok, I'll figure it out -- thanks anyway ![]()
ok..they are explainednin the "how weighted overlay works" section in the tool's help
I know -- thanks. I'm saying I don't understand it
