Raster Calculator problem.
2047
8
02-16-2011 05:00 PM
ChristopherBlinn
I think I may be trying to do something out of my GIS capabilities...
I want to use the raster calculator to create a "relative elevation" DEM.  Currently I have a DEM of an entire state.  The DEM has a 10 meter resolution.  I want the raster calculator to read the input cell value, and then apply a buffer and search the values of the cells within that buffer (say 1000 meters from the input cell) and take the average of those cell values.  Then I want the output DEM to be made of the average values.  Also, I want the new DEM to have a resolution of 1000 meter resolution.
Am I dreaming too big here? If possible, I am pretty sure it will involve some Python scripting.  I am working with ArcGIS 10.0 if that helps in any.  Any feedback is helpful and thank you in advance!
DanPatterson_Retired
PatrickTaurman
ChristopherBlinn
Thank you all for your replies.  Let me work with these grid tools and post back any updates.
ChristopherBlinn
Ran the focalstatistics, and the output raster was a solid black rectangle. Bad right? Well, although it was all black, each cell was calculated correctly and has a significant value.  The symbology of the raster however is all screwed up.  Any ideas why?
ChristopherBlinn
Any way to identify these outliers? Then run a con statement to make sure when the script runs these cells do not have extreme values? Just ideas at this point.
ChristopherBlinn
Okay, so here's the situation.
My original raster has a range of values from 180.8 to 4132.9.  The output raster after running the focal statistics has a range of values from 256 to 3969.2.  The focal statistics script I ran was:
FocalStatistics("RASTERNAME",NbrCircle(1500,"MAP"),"MEAN")
There appears to be no outliers in my data.  Now, could NoData cell values be causing this error?  If so can I run the following to correct for the problem?
FocalStatistics(Con("RASTERNAME","RASTERNAME","",FocalStatistics("RASTERNAME",NbrCircle(100,"MAP"),"MEAN")),NbrCircle(1500,"MAP"),"MEAN")
I think this script would fill the NoData values with an average value calculated by the neighborhood created.  Maybe I am wrong.
I am sorry if I am not making too much sense, I am very new to working with rasters, much of my experience is in vector-based GIS work.
ChristopherBlinn
Attempted running that script, received two errors, 539 and 999999.
Guess I need to try something else.
ChristopherBlinn
Did you know that the "-" symbol can cause a bunch of problems because of syntax rules? Me either, until about 5 minutes ago.
