Raster Calculator Expression
1364
12-29-2013 07:28 PM
SindhuA
I wanted to add the height information of two rasters and create another raster using the raster calculator. In Desktop Raster Calculator Tool the expression for the Same is like this - "Raster1" + "Raster2".
I was trying to implement the same through coding in ArcGIS Engine using a Geoprocessing tool.
The code snippet is as follows:
Geoprocessor gp = new Geoprocessor();
gp.OverwriteOutput = true;
RasterCalculator rasterCalc = new RasterCalculator();
rasterCalc.expression = " '@D:\NewFolder:\Raster1.tif" + "+" + "@D:\NewFolder:\Raster2.tif' ";
rasterCalc.output_raster = "@D:\NewFolder:\Raster3.tif";
gp.Execute(rasterCalc,null);
This is not getting executed and throws an error: HRESULT E_FAIL has been returned from a call to a COM component.
I think there is something wrong with the syntax of the expression.
Thanks in Advance for the help!
Sindhu
curtvprice
Which version of ArcGIS?
Just from a cursory look I'm wondering if your paths should be:
rasterCalc.expression = "D:\NewFolder\Raster1.tif" + " + " + "D:\NewFolder\Raster2.tif";
rasterCalc.output_raster = "D:\NewFolder\Raster3.tif";
Your expression is simple enough you may want to use the Plus tool. That would likely avoid some complications from accessing this functionality from .NET.
SindhuA
Hi curtvprice,
Thanks for the reply. I am using Arc Engine 10. I do not have Desktop SDK to use the PLUS tool. I tried using the paths you have mentioned, but I got the same error again.
Sindhu.
curtvprice
Have you tried this example from the .NET help? It sure looks like an safer approach than using raw pathnames.
ArcObjects .NET Help: Executing a map algebra expression
