I am working with an excel document of lat/long data and I have displayed the xy data and exported the data and now I am trying to run a point density analysis, however I keep receiving the attached error. I am not sure how to create a spatial reference and I don't remember experiencing this problem in the past while running this tool. I am using coordinate system WGS 1984.
I meant the featureclass...
If you open that featureclass's table is there an OBJECTID field?
then export the featureclass so we can have a look at it. If the file is fine, then it is your working environment, which I assume by now, you have changed so that you are working with locally stored data in a simple folder. paths and other unsavoury but permitted environment settings can make a good thing bad.
PS you did check the spaces in path thing?
File received was empty, issue not followed up
