Hi;
I have a question about the optimized hot spot analysis tool. As I see it works like hot spot analysis tool(when you define a fied to the Analysis Field), but you don't have to decide any parameters and also the other option that when you you don't define any field it calculates spatial dispersion with some polygons(Fishnet, aggregation etc..)
Is it true? This is the calculation method, isn't it?
