No Environment Settings for Aggregate Tool in Model Builder.
2292
04-08-2012 07:22 AM
AndreaSoo
Hi -
I am trying to run the Aggregate tool (with Environment Settings adjustments) in Model Builder for a series of rasters to reduce DEM resolution from 1-meter to 30-meter.  However, the Aggregate tool does not provide the Environment Settings option when used in Model Builder.  Why am I unable to batch-aggregate my rasters with Environment Settings and what would be a good work-around?  Any help or advice is greatly appreciated.
Thanks!
Dre
curtvprice
Dre, I believe you're looking in the wrong place, the "Environments" button on the tool dialog is only available when you run a tool interactively.
Within ModelBuilder, right click the tool and pick Environments. ALso, the nice thing about Model Builder is you can also associate environment settings with other elements in the model.
Arc 10 Help: Setting environments for a model process
AndreaSoo
Thank you for this - I have upvoted you.  Of course it's under the Properties...
-Dre
