ModelBuilder - IDW (SA or 3D) - Z value field - Inline Variable Error 001000
4039
09-28-2018 10:53 AM
KeithAbbott
Hello,
I'm not able to use an inline variable (i.e., %Value%) to populate the Z value field of the IDW tool associated with the Spatial Analyst (SA) and 3D Analyst (3D) toolboxes. The Z value field of the IDW tool associated with the Geostatistical Analyst (GA) toolbox, however, does accept an inline variable (i.e., %Value%).
Here's the model:
A precondition for all three IDW tools is the Value variable (shown using dotted arrow lines).
The error generated for the IDW (3D) and IDW (SA) tools is:
ERROR 001000
Z value field: Field %Value% does not exist
I need to use either the 3D or SA versions of the IDW tool, because is contains an Input barrier polyline features field; the GA version does not.
Oddly, the SA and 3D IDW versions accept inline variables for the Output Raster field.
Any idea what the issue could be? Bug?
Is there a workaround?
I'm working with ArcGIS version 10.3.1 for Desktop.
Thanks for your time and any help,
Keith
curtvprice
Instead of using %Value% I would just use the model variable Value from the picklist. If it isn't the right type to show up in the picklist, I would use the Calculate Value model-only tool to convert it to a data type that will work, using the expression r"%Value%" and output data type as Variant or Field (whichever will allow you to connect the output to the IDW tool as the Z field parameter).
DanielRadich
Hey Keith,
It looks like this issue you are running into is most likely a defect correlated to the use of the inline variables. Have you tried running the model in ArcGIS Pro? Do you seem the same behavior with a model in that environment?
Are you able to provide the point data? I am wondering if there is a pre-processing step that we can run that can essentially "Trick" the IDW geoprocessing tool into successfully reading that field value using inline variables.
Cheers,
Danny
KeithAbbott
Hi Danny,
Thanks for your response.
I haven’t tried running the model in ArcGIS Pro.  It's not installed on my system.
I was able to resolve the issue awhile back using ArcGIS Desktop v.10.3.1.
My solution was to change the Point Source Data from Project Data type to model Derived Data type, using the Copy Features tool. For some reason the IDW tool (from the SA toolset) ran successfully when the Input point features parameter was a model derived layer (i.e., Copy Features tool output). So it wasn’t so much an inline variable issue (%Value%) with the Z value field, as I previously thought, but a Input point features issue. I suspected the SA and 3D IDW tools had some issue reading the field names of its Input point features layer, if that layer was not created in the model.
Here’s a picture of my model (clipped), with the Copy Features tool utilized. Project Data type is shown in blue and Derived Data type is shown in green.
Here’s a screenshot of the opened IDW tool (SA).
The warning I get for the Z value field is:
Warning 001000
The model runs fine despite this warning (I guess a 001000 warning is better than a 001000 error).
Let me know if you're still interested in me sending you the Point Feature Class dataset.
I had some issues emailing you the file using the reply to email address, and i don't see an option to attach it to this thread.
Thanks again for your help!
Keith
curtvprice
KeithAbbott
Hi Curtis
Thanks for having a look at this.
Your advice worked.
It was a Data Type issue.
I created a Field data type variable from the Value variable (which has an Any Value data type) using the Calculate Value model-only tool and the equation you provided:
The Value variable does not appear in the Z value field parameter drop-down menu in the IDW tool, however, the Field variable does.
I’m able to select the Field variable from the list…no warnings or errors produced…and the model runs fine
Here’s a picture of the updated model:
Thanks for your help!
Cheers,
Keith
Rick_O_Hara
This seems to be close to the information I was looking for, but I don't think I understand everything. What is the multi value list here.
I've been trying to iterate through values in a field, take input through a parameter, and use the points in an IDW tool. Maybe the answer has been in from of me, but I'm not seeing it.
How do you iterate through a field and set a parameter for each one of the values before it goes to an IDW tool?
Please and thanks. I've been looking for help on here for a while.
