Merge rasters using Spatial Analyst, in ArcGIS 9.3
1639
05-19-2014 10:51 AM
AnnaArbetter
I am getting error messages when trying to merge three orthophotos using Spatial Analyst.
I have been following the recommendations in Forum threads, and I followed the directions in the ESRI support document 20988 "Merge rasters using ArcGIS Spatial Analyst", and I followed the directions in ArcGIS Desktop Help 9.3.
I was careful to make sure each orthophoto has a different name. Also, each ortho is made of four files, and those were the same for each ortho: band_1, band_2, band_3, and band_4. I changed the names so that all 12 parts had different names. (12 comes from this equation: 3 orthos x 4 "band" files = 12)
This is the first error message I got:
ERROR 010316: Unable to open the input grid: C:\USERS\ANNAGL~1\APPDATA\LOCAL\TEMP\Z_Z_Z2 ERROR 010067: Error in executing grid expression.
When I go to the folder to see if there are files in there, I found files named "z_z_z2", "z_z_z3", and "z_z_z4", and each of these looks like a darker version of one of my original three orthophotos.
I'm not sure what I'm doing wrong, or simply what to do next.
Please help if you can -
Thanks!
Anna
TungNg
Maybe something is wrong with the path to the files. Create a folder like C:\gis and put all the files in that folder and try again to see if that would help
Good luck!
MarkBoucher
Honored Contributor
I've found that the shorter the filepath and filename, the less likely I will have problems.
Don't use spaces in the path or names either.
curtvprice
This KB document is does not cover your issue - multi-band rasters.
The inputs can have any name you want (the paths make their names unique), but you need to merge them in this order:
1. Add the bands to ArcMap as individual rasters layers (3 raster x 4 bands - 12 layers)
2. Use the Raster Calculator and the Merge tool (as described in the KB article) to merge all the band 1 rasters.
3. Repeat with the band 2 rasters, band 3 rasters, band 4 rasters
4. Now you should have a raster covering the whole area for each band. Combine them using the Composite Bands tool.
The advice already given about using short raster names (< 10 characters) and avoiding paths that include spaces is sound advice, especially for 9.3.
Hope this helps.
