Mapping elevation
1771
11-17-2016 08:46 AM
LaurieHerrick1
Hello,
   What is the best way to show the difference in elevation between 0-4 feet for about 100 points. I have the spatial extension and I would like to show change over time. Any suggestions?
NeilAyres
Change over time? I think you would have to give us some more info about your data and what it looks like.
And it sounds like you would like to "interpolate" this data into a surface. Lots of potential pitfalls there.
RickeyFight
Do you have access to Pro? This would be cool to show in 3D
LaurieHerrick1
The map will be for a reef that is going to be restored. I will need to show the depth change over time. The downside is the depth change will more than likely be very minimal.
DanPatterson_Retired
As Neil says... interpolate for the two time periods, then subtract the results.  Interpolation approach should use the same method... what is appropriate is a whole new discussion...
Methods are found in the help topics, make sure you read the 'how... works' sections if present
An overview of the Spatial Analyst Toolbox—Help | ArcGIS for Desktop
