Lokking for a Raster Calculator expression
1287
08-09-2013 06:34 AM
JochenScholtes
Dear all,
I have a raster layer and want to reclassify one class based on a rule. Unfortunately I can't find commands for the raster calculator and don't know how to implement it.
Basically I want the Raster Calculator to do the following:
If "my-layer" == 0, reclassify it using a majority filter (8 neighbouring cells)...
Has anyone a clue, how one could implement that?
Best regards.
Muenchner
MarkBoucher
Honored Contributor
I've used the Shift command for this type of thing. In model builder you can automate and trial and error your process.
Tool location: Toolboxes\System Toolboxes\Data Management Tools.tbx\Projections and Transformations\Raster\Shift
Related post for using Shift: http://forums.arcgis.com/threads/75804-surface-angle-in-each-cardinal-direction?p=265962&viewfull=1#...
Luke_Pinner
MVP Regular Contributor
Use Con and FocalStatistics. Something like:
Con("raster"==0, FocalStatistics("raster", NbrRectangle(3, 3, "CELL"), "MAJORITY"), "raster")
Luke_Pinner
Can't edit my previous post for some reason...? Anyways: the following raster calculator expression is better as it will ensure that 0 values don't get included when the FocalStatistics expression is executed:
Con("raster" == 0, FocalStatistics(SetNull("raster" == 0, "raster"), NbrRectangle(3, 3, "CELL"), "MAJORITY"), "raster")
JochenScholtes
Hi all,
sorry for my late response, I was just out of office.
I'll immediately try your versions and report on the outcome.
Best regards
Jochen
JochenScholtes
So I did it like this:
Con("target" == 0, FocalStatistics("target", NbrCircle(5, "CELL"), "MAJORITY"), "target")
It removed all pixels having a value of "0" in just 1 step.
Quite comfortable.
Thanks for all your fast answers.
Best regards
Jochen
