KRIGE Result: please help explain something
2410
10-11-2012 07:12 AM
JamesCrandall
In the attached image it shows a raster output result of a Kriging.  My focus is on the point near the center of the White color cells that is labeled with 7010 (this is the field/value used to Krig).  But if you look at the graduated symbology in the TOC it shows the range as 4509.779643 - 5448.454102
[ATTACH=CONFIG]18363[/ATTACH]
Why is this?  I am expecting the Max to be 7010 (I know this is the highest value found in the point FC).
Also, why is the Min value = -535.5955811?  I am expecting this to be the lowest value found in the point FC.
Sorry for my inexperience with this subject, I am charged with applying some programmatic automation and doing what I can to educate myself on the subject.
Thanks!
MarkBoucher
Honored Contributor
JamesCrandall
So I suppose that this is just the product of the Kriging process itself.  Perhaps I am expecting something more along the lines of what IDW would produce.
I guess my issues is more about not being certain when and why to apply a certain interpolation over another.
MarkBoucher
Honored Contributor
EricRice
Esri Alum
Very good redirect, Mark.
James,  the thing to take away from that pdf in the other thread is that kriging is not an exact interpolator.  The values can exceed the input range, and the surface created will not pass through the sample points.
Best,
Eric
JamesCrandall
Thanks for the info Mark and Eric!
