kernel density by square miles
4115
03-06-2012 06:19 AM
by Anonymous User
Not applicable
Original User: Jim_satx
Ran a kernel density on mass points (65000).  I seem to have forgotten how to obtain density per square mile values from the raster.  My data frame properties are correct (map units feet, etc.) I am currently getting values in the millions when the highest density should be <400 per square mile.  Thanks;
by Anonymous User
Not applicable
Original User: Gaya6337
Make sure the raster is projected before using the Kernel density tool. If your data is stored in a geographic coordinate system, for example GCS_NAD_1983, where the base units are decimal degrees, the results of a density will not be easy to use since they will be expressed in degrees, not a unit like feet, meters or miles. Reprojection of the data would be advisable if your information is in decimal degrees.
-Gayu
by Anonymous User
Not applicable
Thank you very much, that was the problem.
-Gayu
JaredRutledge
Greetings Everyone,
I am sorry for this question, but I am having difficulty performing the reprojection on the fly. My point data are in GCS_WGS_1984.
I go to the kernel density tool, then I select environments.
From Environments I select output coordinates, from Output Coordinates System I select As Specified Below.
This is where I run into a road block can anyone assist me with a step by step guide on how to get these geographic coordinates into something I can use with the kernel density tool?
J
by Anonymous User
Not applicable
Original User: curtvprice
The key is to use the Project tool to project the points into the same output coordinate system as your raster, or at least a projected (not lat-long) coordinate system.
See the response on this [post=390150]other thread.[/post]
