Join points to nearest polygon
1763
07-13-2012 07:46 AM
MikeWissner
Hello All,
I have a point layer that I would like to join to polygons, however, some of the points fall outside of the polygons.  I need to include all the points in the join and was wondering if anyone knew of a method to join the points that fall outside of the polygons to the nearest polygon feature?
Any suggestions would be much appreciated,
thanks, mike
ChristopherBlinn1
Mike,
Could you use the Near tool to find the closest polygon FID for all points?  This will add the NEAR_FID field to the point layer.  You can also add the distance and angle is that is needed as well.
Hope this helps!
Best,
Chris B.
MikeWissner
The results from the near analysis gave me very odd data; the near_fid column had hundreds of objects with a near_fid of -1.
any ideas or other suggestions?
-mike
ChristopherBlinn1
Mike,
Can you provide a sample set of your data?  I can see if the Near tool settings just need tweaking.
Chris B.
