Is it possible to configure SA in a Python script?
3821
11-26-2010 12:12 PM
CedricWannaz
Dear all,
    I have to perform map algebra operations on rasters that have different extents, and I want to obtain an output on the union of the extents. I am doing this in a Python script; is there a way to configure Spatial Analyst output extent to "Union of Inputs" by calling a geoprocessor method from my script?
Thank you and best regards,
Cedric
ArcGIS Desktop 9.3.1, ArcInfo license.
DanPatterson_Retired
Cedric
I haven't had much time to explore all the intricacies of arcpy but you could begin by exploring sa
>>> from arcpy import sa
>>> help(sa.Extent)
provides some clues, if you know the extent that you need, then you can set it
CedricWannaz
Dan,
    Thank you for your answer. Do you know how to do it with the 9.3.1 geoprocessor? I don't have ArcGIS 10 yet, and I am not sure how to access spatial analyst (dedicated-) properties when using the arcgisscripting pyd.
Thank you!
Cedric
Sorry Cedric, don't have a 9.3.x installation here, acrpy does open up a whole new world which didn't exist in previous versions.
RyanDeBruyn
You may need to review the environement settings for extent.
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=2237&pid=2229&topicname=Output_extent
also for Map Algebra in 9.3
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=6311&pid=6308&topicname=Single_Output_Map_Alg...
for example:
gp = arcgisscripting.create(9.3)
gp.workspace = "C:/workspace"
gp.Extent = "MAXOF"
inExpresson = "C:\data\rasterA + C:\data\rasterB"
gp.SingleOutPutMapalgebra_sa(inExpression,"outRaster")
Good luck
Ryan
curtvprice
Here's the 10.x flavor of this:
import arcpy
from arcpy.sa import *
arcpy.env.workspace = r"C:\Workspace"
arcpy.env.extent = "MAXOF"
outRaster =  Raster(r"C:\data\rasterA") + Raster(r"C:\data\rasterB" )
outRaster.save("outRaster")
Output Extent (Environment setting)—Help | ArcGIS for Desktop
