IDW Interpolation
3781
11-08-2010 02:30 PM
PatrickWard
I am trying to create a raster that interpolates weather station rainfall readings (point data) over areas in which there are no weather stations.  When I use the IDW tool, there is an interpolation over the area defined by the northernmost, southernmost, easternmost, and westernmost weather stations, but I would actually like to extend the interpolation beyond these boundaries so that it can later be spatially joined with a polygon shapefile.  Does anyone know if/how this can be accomplished?
DanPatterson_Retired
It would be horrendously easy to simply set the analysis extent to a larger size to extend to your desired boundary, but I would suggest that the results would be meaningless or misleading at best unless you know that such an interpolation would generate valid results beyond the bounds of the input data.   Also, why have you picked IDW as the interpolator given the other options available to you.  Perhaps there is a problem design issue that you could address before settling in on a means to fill in the gaps between stations.
toddsams
You may want to take a look at the PRISM datasets (if you have not already) http://www.prism.oregonstate.edu/products/matrix.phtml?view=data
JoanneDollasin
Hi! I'm Joanne & I'm a newbie in ArcGIS...
I guess my problem is somewhat related to this post....
Specifically, I have a rainfall map (Isohyets) measured in mm
(precipitation)... I wanted to
know a particular value (precipitation) in points between these
lines... how can I do this? Do I have to convert/interpolate these polylines
so I could have a Rainfall raster instead? So that I would know the
precipitation in any point based on cell values of the Rainfall raster? If so,
how do I make a raster map out of my rainfall contours/isohyets? By the way, I
have a DEM of 20-m resolution. Will this be of any help in
converting/interpolating my rainfall map? Pls help.
Thanks & best regards.
JoanneDollasin
