IDW doesn't give results
938
06-19-2023 10:26 PM
DanahAlenezi
Good Day
i faced problems when i use IDW command and it was my first time facing this problem.
the idw dosen't give results as shown below
DanPatterson
MVP Esteemed Contributor
perhaps showing what you did for inputs and outputs would help
Also, which IDW did you use?
and did you have the minimum number of points?
Processing extent correct?
using projected data for inputs?
the list goes on
Also the symbol beside the IDW seems to suggest that it isn't done processing
... sort of retired...
