IDW barriers problem
1122
06-13-2013 11:55 PM
MarcusHumphrey
Trying to create an IDW with barriers, and trying to sort out the barriers, but can't find how to do the barriers, where is the barrier option?
ShaunWalbridge
If you use the IDW tool within the Spatial Analyst toolbox, it should include IDW with barriers. Spatial Analyst.tbx > Interpolation > IDW from ArcCatalog system toolboxes. If you just used a search, you may have pulled up the Geostatistical Analyst version of the tool, which doesn't support barriers.
MarcusHumphrey
Is there a way polygons can be barriers?
SteveLynch
Yes, convert them to Polylines. IDW uses a "line of sight" approach.
