How to symbolize polygons in time-enabled maps
2626
05-30-2011 04:33 PM
FatmaŞenol
My apologies for cross-posting, I have a quick question which I've been trying to find a working solution for weeks. I'm trying to investigate the spatial distribution of cancer data within a province for year 1995, 2000 and 2005. I have exact locations of each cancer patient (without any personal private information) in districts as a point feature class for each year. When I enable the time in
point layer, I can easily see the the change between years just using the slider. But  what I'm trying to do is that to change the symbol of districts (polygons) instead of points. The sample screen-shot is attached.
Of course each polygon could only be  spatially joined to one point. I believe  the solution  could also applies to Tracking Analyst Extension. Thank you for sharing your experience and  suggestions in advance.
Kind Regards
Omur Saygin, Ph.D.
AllisonPlummer
I know this is much later than your original post, but I have an answer for anyone else who is wondering how to do this. I had a similar set up (mine was trees points in neighborhoods) and I wanted a polygon representation of growth of our program over time. I performed a spatial join (polygons to points) and chose to summarize the attributes by Minimum. In the resulting table, the minimum year of a point inside that polygon was recorded in MIN_YEAR and associated with the appropriate neighborhood. I then enabled time on that new layer using the time slider button and assigned MIN_YEAR as the date field and set the other preference accordingly. This method doesn't relfect any sort of concentration over time, but it does give you a nice overview of simple growth over time.
Hope that helps!
