How to perform the �??Create Thiessen Polygons�?� within the study area?
11304
12
11-02-2011 10:25 AM
JamalNUMAN
Legendary Contributor
Please, see the attached image that shows my question
In ArcGIS, it is not easy all the time to perform some tools so that the output is bounded by a given study area, for example:
- If we need the output of the tool �??Create Tin�?� to be bounded by the study area then we  set a boundary layer as �??Softclip�?� (see screenshot)
- Concerning the spatial analyst tools, we  set the boundary layer to be the mask (see screenshot)
Then how to let the output of the tool �??�??Create Thiessen Polygons�?� bounded by certain study area?
Thank you in advance,
Regards
Jamal
Jamal Numan
DanLee
by Esri Regular Contributor
An enhancement for this has been raised for a future release. For the time being, if you are talking about only one study area, you can run Clip tool to clip the Thiessen polygons by the study area polygon. If you have multiple study areas in the same feature class, you would need to do this one study area at a time in a loop (iteration).
JulieZamudio
Has this enhancement been added?
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Thank you Dan for the answer. that's great that this enhancement will be included in a future release.
Could you please elaborate more how can i make a loop (Iteration) so that i can perform this command (Create Thiessen Polygons) considering more than one study area?
appreciated
regards
Jamal
DanLee
Here is an earlier discussion on the same subject. Have a look:
http://forums.arcgis.com/threads/4372-Run-Thiessen-polygons-to-a-specific-boundary-shapefile
Hope you can solve the problem using that solution.
by Anonymous User
Not applicable
Original User: farshad171
Hi
I want to create Thiessen polygon within a watershed by using point data. I am using Arcgis 9.3 with all component. The problem is that, there is no '' Create Thiessen polygone'' tool in proximity function.
In proximity I just have Buffer and Multiple ring buffer. Do you know what's wrong with it? I am lost in the the middle of an assignment.
Best regards,
DanLee
Perhaps you have the ArcView or ArcEditor license. You will need the ArcInfo license to get the Create Thiessen Polygons tool.
by Anonymous User
Not applicable
Original User: ciava.at
I have made with arcobjects if you haven't license arcinfo: https://github.com/nicogis/Voronoi
I intersect with envelope ( https://github.com/nicogis/Voronoi/blob/master/GeometryVoronoi.cs#L180 ) but you can change with your polygon (study area)
JamalNUMAN
Thanks Domenico
Best
Jamal
Jamal Numan
