how to interpolation contour?
5927
08-04-2014 05:48 PM
MonyrothLy
i have contour points and elevations, however it not work when use the interpolation in arc toolbox..... help and explain me please......
Tags (1)
DanPatterson_Retired
check the help files for TopoToRaster   This requires the Spatial analyst extension
JorgeOrellana
I would suggest reading the Help files provided with ArcGIS. In the Spatial Analyst toolbox, there are a few toolboxes that will interpolate the points to a surface using various methods. Each tool has help associated with it (just right click and select Help) some are very simple tools and some use some very complex formulas to interpolate the surface. There is a a lot of useful information in the help.
In short, you will take your points convert them to a raster,  then take your raster and create the contours from it.
MonyrothLy
Thank you so much.....
