How do I covert Scientific E Notation to number in ArcGIS?
3376
02-19-2021 08:36 PM
Shareful
While analyzing a dataset of NASA, I'm having a Scientific E Notation number like 7.60907e-06. Do you know how do I covert it into the real number in ArcGIS?
Pls suggest. A screenshot is attached for your understanding.
DanPatterson
MVP Esteemed Contributor
It is a real number... you just have to move the decimal place six places to the left
a =7.60907e-06
float(a)
7.60907e-06
"{:16.10f}".format(a)  # ---- use
'    0.0000076091'
# --- now for a brain twister
a = 7.60907 * 1e-06
a
7.609069999999999e-06  # --- floating point representation
# ---- now
a = 7.60907e-06 * 1000000.
7.60907
... sort of retired...
Shareful
@DanPatterson many thanks. I'm so sorry, I'm not so good at ArcGIS so far. Would you kindly let me know how do I execute it? Using Raster calculator or what?
DanPatterson
Raster calculator would be the easiest.
But why would you want to multiply the raster by 100000 since it will change your actual values.
Your values are small, perhaps you could tell us what the values represent in the first place
Shareful
I want to change the number, because it (Scientific E Notation number)  does not allow me for any further spatial analysis. Even I can't convert from Raster to Point too. Small number is fine for me.
I can't multiply 100000 with the raster image too.
DanPatterson
Raster to Point (Conversion)—ArcGIS Pro | Documentation
either floating point or integer rasters can be used... which is strange because scientific notation is still floating point.
did it work when you scaled up the values?
