How can I get Elevation, Slope, and Aspect for certain Points on a map?
6594
09-08-2011 09:34 AM
TaitRounsaville1
I have a point layer of some locations in the local mountains with x,y coordinates and I have them over a DEM of the area. I ran a Slope and Aspect tool using the DEM and it came out correctly. My question is how, other than hitting "info" and clicking near each point on each layer, since there are a hundred points, can I get the elevation, slope, and aspect for each location where these points fall on the map?
Thank you
EricRice
Esri Alum
Greetings,
Run the Extract Multi Values to Points tool.  Attached is how I set the tool up, and the resulting point attribute table.
If you don't have ArcGIS 10, you can run the Extact Values to Points tool or the Sample tool.
Regards,
Eric
TaitRounsaville1
Thank you very much. The screen shots are very helpful. I am using 9.3 and didn't see a multiple values option but sometimes not all tools show up on this machine, so I just did them individually and joined them.
