Georeferencing Toolbar missing in 10.3?
8841
12
09-04-2015 01:27 PM
TommyDye
I am trying to georeference a scanned tiff image, however when I turn the georeferencing toolbar on in customize toolbars nothing happens normally a greyed out toolbar is launched that turns active when an unreferenced image is loaded.  it was working fine in 10.2 before the upgrade to 10.3.Is this a bug in 10.3? Or have I simply failed to turn on a supporting feature (both spatial and 3d are on and working)
OS: Win7
Arc Version: 10.3.1 Advanced for desktop
Extensions: Spatial Analyst, 3D Analyst, Terrago,
Dual Monitors
Thanks
TommyDye
PROBLEM SOLVED!!
The other GIS Tech who last used the machine (6 months ago) had the monitors reversed with the right monitor as the main and the left as secondary when I made the left monitor primary it pushed the un-docked toolbar into no-mans land. It kept this setting (Right monitor primary) even when plugged into a single monitor, I think due to some conflict between the default windows display manager and the HP display manager.
JessiecarEsguerra
Do you have the basemap on your arcmap when you drag the tiff image? I have the same problem previously in 10.2 and what I did is remove the basemap, drag the tiff image first then add back the basemap and then I was able to proceed in georeferencing process.
Give it a try if that is the case you have.
TommyDye
I have tried it with both blank projects and with exiting projects with data. I am stumped. Even after a clean install it is still missing.
Thanks
JessiecarEsguerra
Try to change the image from tiff to jpeg format and see if it will work.
This is also one of the workaround i applied when dealing with the same problem though i'm using 10.2
If it will not work, maybe you are right that it could be a bug on 10.3
TommyDye
I will give it a try next week.
Thanks
JayantaPoddar
Hi Tommy,
It might happen with a Dual Monitor system. Check the other monitor if the Georeferencing toolbar is opening there.
Think Location
TommyDye
I really hope its as simple as unplugging one monitor.
JayantaPoddar
If this is the issue, you can just drag the toolbar from Monitor-2 to Monitor-1 or vice-versa.
Think Location
TommyDye
It's not showing up on either monitor.
JessiecarEsguerra
Hi Tommy, were you able to try it? Changing .tiff image to .jpeg image?
Just curious if that will work on your end.
