Floow accumulation with relative elevation
1807
07-17-2011 08:53 AM
RicardoBarbas
Hello everyone,
I'm new to arcGIS, and in this project i'm working on, i need to resort to a specific hydric erosion model that is based on the cumulative relative elevation of the flow. What i need to know is if its possible to apply the cumulative relative elevation of the upstream cells on the flow accumulation tool, or if there's any script that can help me.
I also need to apply the same principle but with cumulative slope angles (in degrees).
Thanks in advance
PavanYadav
You need Spatial Analyst. Here is a good starting point.
An overview of the Hydrology toolset
Regards,
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
ChrisSnyder
Honored Contributor
Here a sniipit of some Python code that builds "accumulated" elevation, slope, curvature, etc. grids - these grids are used as part of a DEM-based stream perdiction model.
Note: flowDirLclGrd = a flow direction grid derived from a filled DEM.
flowAcc1Grd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\flowacc1"
gp.FlowAccumulation_sa(flowDirLclGrd, flowAcc1Grd, "", "FLOAT"); showGpMessage()
#Process: Builds a flow accumulation grid - accumulated acreage
flowAcc2Grd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\flowacc2"
somaExp = "FlowAccumulation(" + flowDirLclGrd + ") * " + str(int(gp.cellsize) * int(gp.cellsize)) + " / 43560"
gp.SingleOutputMapAlgebra_sa(somaExp, flowAcc2Grd); showGpMessage()
#Process: Builds a flow accumulation grid - of estimated CFS using only watershed area and precip
pcpGrd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\pcp"
gp.Resample_management(precipGrd, pcpGrd, gp.cellsize, "BILINEAR"); showGpMessage()
flowAcc3Grd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\flowacc3"
somaExp = "flowaccumulation(" + flowDirLclGrd + ", " + pcpGrd + ", 'FLOAT') * " + str(int(gp.cellsize) * int(gp.cellsize)) + ") / 12 ) / 31556926" #31556926 = seconds/year
gp.SingleOutputMapAlgebra_sa(somaExp, flowAcc3Grd); showGpMessage()
#Process: Reclassifies any 0s flowAcc1Grd to 1 (which makes it so that we can use division (aka can't divide a grid by another grid if the denominator has a 0 in it)
flowAcc5Grd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\flowacc5"
somaExp = "con(" + flowAcc1Grd + " == 0, 1, " + flowAcc1Grd + ")"
gp.SingleOutputMapAlgebra_sa(somaExp, flowAcc5Grd); showGpMessage()
#Process: Builds an accumulated elevation grid (uses the fil2LclGrd)
accElvGrd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\acc_elev"
somaExp = "flowaccumulation(" + flowDirLclGrd + ", " + fil2LclGrd + ", 'FLOAT') / " + flowAcc5Grd
gp.SingleOutputMapAlgebra_sa(somaExp, accElvGrd); showGpMessage()
#Process: Builds an accumulated slope grid
accSlpGrd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\acc_slp"
somaExp = "flowaccumulation(" + flowDirLclGrd + ", " + slpGrd + ", 'FLOAT') / " + flowAcc5Grd
gp.SingleOutputMapAlgebra_sa(somaExp, accSlpGrd); showGpMessage()
#Process: Builds an accumulated curvature grid - fancy stuff is to deal with negative values
accCurGrd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\acc_cur"
somaExp = "(flowaccumulation(" + flowDirLclGrd + ", max(" + curGrd + ", 0), 'FLOAT') - flowaccumulation(" + flowDirLclGrd + ", max(-1 * " + curGrd + ", 0), 'FLOAT')) / " + flowAcc5Grd
gp.SingleOutputMapAlgebra_sa(somaExp, accCurGrd); showGpMessage()
#Process: Builds an accumulated profile grid
accProGrd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\acc_pro"
somaExp = "(flowaccumulation(" + flowDirLclGrd + ", max(" + proGrd + ", 0), 'FLOAT') - flowaccumulation(" + flowDirLclGrd + ", max(-1 * " + proGrd + ", 0), 'FLOAT')) / " + flowAcc5Grd
gp.SingleOutputMapAlgebra_sa(somaExp, accProGrd); showGpMessage()
#Process: Builds an accumulated plan grid
accPlnGrd = root + "\\" + areaFolderName + "\\" + origOidFolderName + "\\acc_pln"
somaExp = "(flowaccumulation(" + flowDirLclGrd + ", max(" + plnGrd + ", 0), 'FLOAT') - flowaccumulation(" + flowDirLclGrd + ", max(-1 * " + plnGrd + ", 0), 'FLOAT')) / " + flowAcc5Grd
gp.SingleOutputMapAlgebra_sa(somaExp, accPlnGrd); showGpMessage()
