extracting values from raster
1236
08-01-2013 05:00 AM
ChristianAndersen
Hi all,
Its been some years ago since I worked with rasterdata for real, so I have to brush up my knowledge on this subject. Hope you guys is able to help. 🙂
I have a raster file (img) containing gridcells with values represent floodvalues (0,1 representing 10 cm water on the surface). I want to extract the cells with more than 10 cm water on the surface. I´ve tried with the extract by attributes, but somehow there isn´t a attribute to select?! If I use the info selection on one cell I get the stretched value and the pixel value (which is equel to the amount of water) so there must be a value somewhere that I should be able to extract on.
What am I missing? Can somebody please guide me in the right direction?
Thanks in advance
Christian
MarkBoucher
Honored Contributor
DanPatterson_Retired
are you using the raster calculator (map algebra in ArcToolbox)?  if it is an integer grid you want to query for values > 1
